MultiWiiKopter-Konfigurationsprogramm für Arduino
yacco
#916 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von yacco »
Hi Alouette,
I'm currently very busy, so I guess it will take some weeks to update the LCD_Config to 1.9. Another problem is that I don't see any personal need to update my WMP-only copters. Did you try the TEXTSTAR mode (i.e., the LCD_Config simulates a TEXTSTAR display, so you can use the built-in configuration in the MWC code).
Ciao, Arnd
AlouetteIII
#917 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von AlouetteIII »
Hi Yacco - how about I send you a free PARIS v4 Sirius Navigator Board? Would that help ? - the ACC is super smoother and the MAG work very well to lock the heading on the PARIS - Really - Acc is as good as 1.7 again ( I never could use it under 1.8 ) - so overall makes for a very nice filming platform in 1.9. My first few flights I found the MP+ was not as good as it was in 1.8.2 - but the 3200 Gyro feels great now in 1.9 - I also have the Eagletree I2C LCD - but to be honest mate, I really like your software Yacco - so you need a reward I think! Then I can enjoy it in 1.9 again.... :) cheers Quinton
yacco
#918 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von yacco »
Here we go...
Update 4.1
This is an early beta version which supports MWC v1.8 and v1.9 and lacks the new GPS features in v1.9. So far, only the communication routines have been adapted. Seems to work with both v1.8 and v1.9, but I haven't tested it in depth.
Have fun...
LCD_Config_410beta.zip
(90.2 KiB) 144-mal heruntergeladen
Ciao, Arnd
muggel117
#919 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von muggel117 »
SUPER Arnd, DANKE!
Ich habe es gerade mit der MultiWii_dev_20111029 (welche ja der "Grundstock" der 1.9er sein soll) getestet und es scheint einwandfrei zu funktionieren.
Der einzige Bug (wenn man es denn so bezeichnen will) den ich gefunden habe, die grafische Anzeige der ACC-Werte (das --> __I__ __I__ ) funzt nicht.
Da ich es aber eh nicht nutze, ist es für mich eher ein "Schönheitsfehler" als ein Bug.
GPS habe ich nicht, daher kein Test möglich.
Alles in allem hast Du mal wieder saubere Arbeit geleistet! :thumbup:
Gruß Frank
yacco
#920 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von yacco »
Bei mir geht das. Hast du die Option GRAPHIC aktiviert?
Ciao, Arnd
muggel117
#921 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Hi Arnd,
k.a. was es war, aber jetzt geht es bei mir auch - obwohl ich nix geändert habe.
Suuuuuuper Sache das! Endlich wieder Configtool benutzen. :hello1:
Der Textstarmodus war ja auch 'ne Zumutung für's Infieldconfig, funzt zwar auch,
aber wenn man sich an etwas besseres gewöhnt hat, ist Textstar ein echter Rückschritt.
Gruß Frank
Luxar
#922 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von Luxar »
Hallo!
Vielen dank für 4.1 !!
Ich hab bei mir folgende Beobachtungen gemacht:
Bei multiwii Software 1.9 :
Wenn ich im Menü "Rates" im Bereich Batt und Co war und denn wieder zurück in anders Menü will,hängt sich die config auf...
Und das Profile mit nem Namen speichern scheint auch nicht zu funktionieren...
Bei multiwii Software 1.8.2 :
Auch das mit dem Batt Menü,das sich die Software aufhängt...
Aber Profile mit Namen speichern geht...
Sonst alles soweit ok.
Gruß Ralf
Gruß Ralf
yacco
#923 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von yacco »
Hi Ralf,
das Aufhängen im Battery-Zustand kann ich zwar nicht nachvollziehen, aber der Wert von PowerTrigger wird nicht korrekt ans MWC-Board geschickt, werd ich mal checken. (Wäre möglich, dass das Problem durch eine Änderung, die ich nach der 4.1beta gemacht habe, schon gefixed wurde). Auch den Bug beim Laden der Profile kann ich reproduzieren (scheint nur beim ersten Profil zu funktionieren), wird sofort beseitigt. Danke für die Infos.
Dem Update auf die 4.1 Release steht sonst nichts mehr im Weg, ich habe für die GPS-Parameter ein paar neue Unterpunkte eingefügt und die Unterpunkte, die aus dem Startzustand erreicht werden konnten, etwas besser strukturiert (macht das ganze jetzt hoffentlich etwas überschaubarer).
Ab sofort werde ich die neueste Release nicht mehr in den ersten Beitrag des Threads einfügen, sondern nur noch ans Ende des Threads mit einem Link vom Wiki. Wer also die neueste Release sucht und nicht immer die letzten Beiträge danach durchsuchen will, setzt sich am besten einen Shortcut auf die Wiki-Seite.
Ciao, Arnd
Luxar
#924 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von Luxar »
Danke Arnd,das du so schnell bei der Sache bist !!!!
Gruß Ralf
yacco
#925 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von yacco »
Update 4.1 beta 2
* Bugfix beim Serialisieren
* Bugfix beim Speichern/Wiederherstellen der Profile
* Bei der Auswahl der Profile wird jetzt auch die Version angezeigt, mit der das Profil erzeugt wurde.
* Änderung der Untermenüstruktur im Zustand "0 - Config". Statusanzeige, Kalibrierung, Activation Modes sind jetzt über RIGHT im Startzustand zu erreichen.
* Anzeige der GPS Daten und Setzen der GPS-Activation Modes (wird von der MWC Software noch nicht unterstützt)
Hinweis: Der Wert von PowerTrigger kann nur dann geändert werden, wenn im MWC Sketch die Konstante POWERMETER definiert ist. Ansonsten schickt das MWC nach dem Schreiben wieder den Wert 0 zurück.
LCD_Config_410beta2.zip
(90.49 KiB) 121-mal heruntergeladen
Ciao, Arnd
Luxar
#926 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von Luxar »
Hallo!
Hab beim Compilieren der 410 beta 2 folgende Fehlermeldung:
Neue Bitmap.jpg (131.31 KiB) 1952 mal betrachtet
Gruß Ralf
Luxar
#927 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von Luxar »
Hab den Fehler gefunden: im Rot eingekreisten,hinter der 0,muss noch`n komma...(hoff ich doch...jedenfalls gehts jetzt)
Neue Bitmap.jpg (132.16 KiB) 1949 mal betrachtet
Gruß Ralf
yacco
#928 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von yacco »
Oops... Notiz an mich: keine sinnlosen last minute Patches mehr einbauen. Wird im Release geändert, einen neuen Patch braucht es deswegen wohl nicht.
Ciao, Arnd
Luxar
#929 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von Luxar »
Nabend !
Dafür hat man doch "Versuchskarnickel" :wink:
Alles wird gut !!
Gruß Ralf
yacco
#930 Re: MultiWiiKopter-Konfigurationsprogramm für Arduino
Beitrag von yacco »
Ja, wenn ich nicht ab und zu absichtlich kleine Fehler einbaue, krieg ich ja gar kein Feedback mehr... :mrgreen:
Ciao, Arnd
Zurück zu „Allgemeines“
