#1 Welcher T-Rex ist besser???????????
Verfasst: 14.06.2006 23:14:50
Möchte mir gern noch einen T-Rex kaufen und kann mir jemand sagen welcher der beiden ausführungen der bessere ist?
Bin ein absoluter Anfänger in Englisch und in meinem Duden find ich nicht alle wörter!
!!!HELFT MIR BITTE!!!
1) T-REX 450SE Kit/Black V2 + Motor 430L+35G Bl Regler
English :
Instructions:
?Arrived with 80% pre-assembled?
T-Rex 450 Superior Edition (eCCPM) represents the state of the art in micro helicopter technology, utilizing the latest design techniques and highest material quality, aluminum parts are anodized in a pleasant blue color and carbon assembly. This kit is for the flyers who want uncompromised performance and quality. This SE arrived with 80% pre-assembled!
- New CNC carbon frame only 1mm, improve the rigidity and perfect for 3D flying.
- Changing servo location to CCPM version, new aluminum parts for prompt, precision actions.
- Battery mounting plate connects to main frame. It makes the center of gravity closed to rotor blade, reduced the correction when the heli rotation rolling.
- Rigid CNC aluminum rotor head for precision and smooth movements.
- Using Ball and Hill two systems mixing control. Through simple structure of Ball control system, power-saving of Hill system and CCPM control, can simultaneously control 3 servo for AILE, EVLE, PIT 3 actions. This CCPM control system is great for 3D flying control and extending life cycle of servos.
- New streamlined carbon tail rotor blades makes the gyro more efficient.
- New tail rotor control set, CNC control piece and movable ball link for smooth pitch travel.
- Providing flybar weight- When normal flying, you can add the weights on flybar paddles for stable flight. When aerobatic flying, you don′t need to add the weight, but you can see the flexibility of 3D actions.
- CNC Metal tail unit and tail holder are using high rigid aluminum, falling resistance.
-Use 32pcs precision bearing.
-Use CNC high precise alumium alloy linkage ball.
-Great stable and sensitive mixing lever design! Can disply the great stability and precision for 3D flight.
-T-REX 450SE special adjustable pitch system, hold rotation system, tail rotor drive belt system! It is a work of great originality for helicopter!
Features
1.32 Precision Bearings
2.Auto-Rotation System
3.Rear Tail Servo Mount
4.Collective Pitch System
5.Tail Rotor Drive Belt System
6.Main Drive Gear with Cooling Fan
7.Professional Servo Control Lever Design
Specification:
Length:650mm
-Height:230mm
-Main Rotor:680/700mm
-Tail Rotor:150mm
-Motor Gear:15T/13T/11T
-Main Gear:150T
-Autorotation Tail Drive Gear:109T
-Tail Drive Gear:22T
-Drive Gear Ratio:
1:10:4.95/1:11.5:4.95/1:13.6:4.95
-Weight(without power system):365g
-Weight(including power system):690g
Accessories:
-T-REX 450SE Kits SetX1 set
-325 PRO Rotor BladeX1 set
-315 Carbon Rotor BladeX1 set
-Aluminum CaseX1
-RCM-BL35G 35A Brushless ESC(Govener Mode)X1
-430L Brushless motor(3550KV)X1
2) T-REX 450SE Kit/Silver + Motor 430L+35G Bl Regler
English :
!Arrived with 80% pre-assembled!
T-Rex 450 Superior Edition (eCCPM) represents the state of the art in micro helicopter technology, utilizing the latest design techniques and highest material quality, aluminum parts are anodized in a pleasant blue color and silver SSG carbon assembly. This kit is for the flyers who want uncompromised performance and quality. This SE arrived with 80% pre-assembled!
- New CNC SSG carbon frame only 1mm, improve the rigidity and perfect for 3D flying.
- SSG battery mounting plate connects to main frame. It makes the center of gravity closed to rotor blade, reduced the correction when the heli rotation rolling.
Features:
Specification:
-Length:650mm
-Height:230mm
-Tail Rotor:150mm
-Main Gear:150T
-Drive Gear Ratio:
Accessories:
-Aluminum CaseX1
Grüße Stevie
English :
Instructions:
Features
Specification:
Length:650mm
-Height:230mm
-Tail Rotor:150mm
-Main Gear:150T
-Drive Gear Ratio:
Accessories:
-Aluminum CaseX1
English :
Features:
Specification:
-Length:650mm
-Height:230mm
-Tail Rotor:150mm
-Main Gear:150T
-Drive Gear Ratio:
Accessories:
-Aluminum CaseX1
Grüße Stevie
