Hier staubt noch ein Regler Align RCE-BL75G ein. Hat 9 Flüge im T-Rex 600 hinter sich. Hier die Daten:
English :
Fearture:
• Three programmable throttle speed settings to support quick throttle response.
• Govener Mode(governor speed controller¡Bslow down system)
• Small and compact PCB design for ease of installation.
• Large heatsink for great thermal performance.
• High compatibility to work with 98% brushless motors in the market.
• Ultra smooth motor start design to run with all kinds of brushless motors.
• The power inlet adapts Japanese made "Low ESR" capacitor in order to provide stable power source.
• The throttle has more than 200 steps resolution that provides great controlling sense.
• Users can use the transmitter to operate the motor setting by Super stylized CPU.
• approval(0503028)¡B approval(0503116)¡C
164" colspan="2" valign="top" bgcolor="#FFFFCC">• Contimuous current:75Amps with porper air flow
• Surge current:100Amps for 15seconds
• Supporting motor types:2 poles to 10+poles in/outrunner brushless motors
• Supporting maximum RPM:2poles=>190,000rpm
• Supporting input voltage:5.5V~25.2V
• Supporting battery types: Li-ion/ Li-poly 2~6 cells, Ni-Mh 6-18 cells
• Size:72X28X11mm
• Weight:53.7g
NOTE: Not including BEC. User need to provide the power for receiver and servo.
Der Regler kostet neu 90,-€. Ich denke 65,- incl. Versandkosten sind OK?
Align RCE-BL75G
