Neue AirWare für Dx9/10/18
Yaku79
#1 Neue AirWare für Dx9/10/18
Beitrag von Yaku79 »
HorizonHobby hat geschrieben:
New Features & Improvements
• Swash setup with reversed channels no longer needs to be done on opposite throw.
• Characters can now be inserted or deleted while editing text. Simply select the insert character <+> or the delete character >-< while editing.
• “Auto-zoom” on the mix curve edit screen will show wave at 10x magnification when there is room on the display.
• Flight Mode switch can now have position values defined for each flight mode using the Digital Switch Setup screen. This is ideal for multi-copter flight mode control, but all switches may be redefined.
• Flight Mode may be used as a mix input or channel input source. It will use the values defined in the Digital Switch Setup screen as if they were analog inputs.
• Added “no image” as an option for all model types and enabled several trans-model type icons.
• Vario graph width does not reset every power cycle.
• Telemetry alarms are suspended while editing telemetry settings.
• Improved reasonable options for sailplane throttle switch inputs.
• Improved import/export compatibility between all radio types (except DX7s/DX8)
Corrections
• Models 50 and above now bind properly.
• Translation improvements for all languages.
• Model image now exports.
• Improved import/export for many features including combo switches, sub-FM rates, timers, and telemetry features.
• Mixes for 6-aileron wings function properly now.
• Trainer status is now voiced correctly, based upon settings.
• Gyro trims re-enabled in Heli mode.
• Flight Mode Name editor has been re-enabled.
• Telemetry Log switch operation force-enabled properly.
• Removed 10% curve mix limitation.
• E-Ring is now properly disabled for swashplates where it is not supported.
• Improved warning for re-mapped channels which use switch inputs.
• Mixing flaps to one channel would occasionally result in the mix being applied to all channels. This has been fixed.
DX9 Audio System Changes
• Improved support for Sky Zone and Fat Shark head trackers.
• Improved reliability of sound file transfers.
• Improved ability to cancel sound transfers. You still must power down after a transfer abort.
• Corrected swap of vario vs. warning volume settings .
geissi
#2 Re: Neue AirWare für Dx9/10/18
Beitrag von geissi »
Hallo FW-Updater,
ich habe meiner DX18 heute die neue 1.06 FW aufgespielt. Die Modelle wurden vorher gesichert.
Nach dem Aufspielen des Updates ließ sich leider keines meiner Modelle mehr binden.
Die orangene Lampe an der DX18 ging auch nicht mehr an - kein HF-Signal.
Lösung: Einfach das FW Update nochmal laufen lassen. Bei mir hat das geholfen.
Wenn das auch nicht hilft, den Akku abklemmen und nochmal versuchen.
Danach ließen sich die Modelle wieder binden.
Vorsicht: Die Warnungen beim Einschalten müssen eventuell teilweise neu
gesetzt werden (Schalterpositionen).
Rolf
Zurück zu „Sender“
