Roxxter 33 CARBON
Carstensen
#1 Roxxter 33 CARBON
Beitrag von Carstensen »
Hi Roxxter flires
Here is my first pictures of my Roxxter 33, I start building from 1 week ago, and now i am 75% done.
More pic will follow next week, this Roxxter 33 is a truly state off art, Damm, it is so easy to build and the parts is really great stuff, but I will make some small upgrades/ changes over time
Br
Carstensen
Later on I will hope to write in Germany, need practice WOTE FOR ENGLICH MANUAL :lol:
crash
Beitrag von crash »
Rear future Roxxter pilot: -) I fly for 4 months the Roxxter 33 and can to you only say, flies makes still MORE fun like a building lol I wish you a mad Roxxter season. Greeting walter from Duesseldorf
:D :lol: :D :D
unschaf
Beitrag von unschaf »
Nachdem Du ja sagst, Du brauchst Übung, schreibe ich in Deutsch.
Ja, der Roxxter ist ein geiles Teil, würde auch mich reizen, aber das is einfach zuviel Geld für einen Hubschrauber.
Viel Spaß damit, Grüße, Gernot.
>>Eco Piccolo V2 Brushless Airwolf, CDR-Motor, Tsunami 10.
>>T-Rex Freestyle MP, Carbon Chassis, Tsunami 30, DH400, GY-240
>>Kyosho Caliber 5 / OS50SX-H
Multiplex EVO9 Scanner.
Carstensen
#4 Roxxter 33 Update
Hi there - and thanks for comment, just make an extra plate on the bottom :D
The lipo is home made and is a 6s2p 4500 mAh 20 C weight 700 gram and with Carbon crash box the total is 850 gram
(crashbechti) Are you using the 17 pinion or the 18, and is there any differens in flying time ???
More to Come :lol:
Carstensen
Hmm, you reached the limit of the JAZZ (voltage).
No problems so far?
I'd tend to a JAZZ 50, because of the high voltage.
Carstensen
No the Jazz is designed to work with the 6s 22,2 V and the total load is Almost 85Amp and the Jazz will work up to 100 amp short, so i dont understand your point
Br
Carstensen
Carstensen hat geschrieben:dont understand your point
Actually, my point is:
JAZZ 80-6-18, max 18x1,2 V => 21,6 V.
So, you're out of waranty ...
Carstensen
Ok I see the point, in the manual for the Jazz it accept 24 V, and Lutz F is reccomende working with 6s=24 V, for the Jazz 80-6-18 but anyway i hope it will take the heat, there is no problem so far, it is only getting low hand warm, but i havent try for flying yet
Br
Carstensen
Sounds good to me.
I'll try to migrate all my heli to Jazzez.
So, good point, when you have no trouble with the 80 :)
crash
#10 Roxxter-Jazz
Beitrag von crash »
Hi Roxxter -Pilot
:wink:
Bei 18 Zellen GP 3700 liegt meine Flugzeit bei 8 Minuten :(
Gut zu wissen( wenn ichs Richtig verstanden hab) der Jazz bis 24V Cool bleibt <g>
Dient die untere CFK Platte als versteifung
oder wieso ist sie Montiert ?? Schau dir mal die Bilder vom Roxxter 33 hier im Forum an !! Meine Lipos sind Bestellt...6S2P---6S Kokam und 6S High Power :-))) Ich kann es kaum erwarten <bg> Also bis zum nächten Bericht von deinem ERSTFLUG lol
Gruss Walter
ingo777
Beitrag von ingo777 »
nice bird carstensen! have just browsed thru the specs of the 80-6-18, no probs found 80 amp cont. peak 100 for 15sec. handling 25V with BEC. however in the threeDMP world have been probs with the JAZZ BEC and you may want to consider SBEC or UBEC instead, for peace of mind, or even a RX battery.
have fun and merry xmas!
ingo
Larsen
Beitrag von Larsen »
tracer hat geschrieben: JAZZ 80-6-18, max 18x1,2 V => 21,6 V.
What does the "-6-" stand for, then? I expected it to be the number of possible lipo cells.
Beitrag von helihopper »
No,
for the minimum of NiCd / NiMh Cells.
ingo777
correct, its for NI cells.
ingo
Danny-Jay
Beitrag von Danny-Jay »
RHF goes Multi Lingual :D
Zurück zu „Roxxter“
