Irgendwie klappt es nicht mehr meinen 1.Beitrag zu ändern, hier die aktuelle Liste:
staebchen-----------------------------------------------------------------------------------------------------------------------7HV---------------13125 Berlin
Sven-Hamburg----------------------------------------------------------------------------------------------------------6HV---7HV---------------22885 bei Hamburg
Zoul-------------------------------------------------------------------------------------------------------------------------------7HV---------------32052 Herford
jdammeyer----------------------------------------------------------------------------------------------------------------------7HV---------------32469 Petershagen bei Minden
Clou--------------------------------------------------------------------------------3DPlus--XSport--------------------6HV-----------------------32602 Vlotho an der Weser
Felix62---------------------------------------------------------------------------------------------------------------------------7HV---------------32689 Kalletal
Uli4G3--------------------------------------------------------------------------------------------------------------------6HV---7HV --------------33729 Bielefeld
Mike1503---------------------------------------------------------------------------------------------------Atom550----------7HV---------------39615 Seehausen
Heli1966------------------------------------------------------------------------------------------------------------------6HV---7HV--------------56637 Plaidt
Pietbaer--------------------------------------------------------------------------------------Atom 500--------------------------------------------65185 Wiesbaden
Belt V2 Crasher/ Wizard-----------------------------------------------------------------------------------------------6HV-----------------------65812 Bad Soden am Taunus
testpilot--------------------------------------------------------------------------------------Atom 500 FBL---------------------------------------73066 Uhingen
Sebastian Zajonz----------------------------------------------------------------3Dplus---Atom 500--Atom550---6HV---7HV--------------74626 Bretzfeld
Alex2707---------------------------------------------------------------------------------------------------Atom 550------------------------------82431 Kochel/82256 Fürstenfeldbruck
Felix
T-Rex 450 Pro FBL / DS92A+ / DS520 / Jazz 40-6-18 / Brain /
Compass 7HV FBL / SZ4926 / MKS BLS 950 / MKS BLS 990 / Kosmik 160 / Brain
Blade MCPX Bl.............................. Sender : MX 16 Hott, Mode 3 Flieger
Akkus vorgewärmt by "HeatBox" Wer nicht hoch fliegt, kann nicht tief fallen !
Heli1966-----------------------------------------------------------------------------------------------------------------6HV---7HV---------------56637 Plaidt
Sonny-1889---------------------------------------------------------------------------------------------------------------6HV----------------------83026 Rosenheim
Felix
staebchen--------------------------------------------------------------------------------------------------------7HV----------------13125 Berlin
chris81sn---------------------------------------------------------------Atom 500---------------------------------------------------19057 Schwerin
Sven-Hamburg-----------------------------------------------------------------------------------------6HV-----7HV----------------22885 bei Hamburg
Zoul----------------------------------------------------------------------------------------------------------------7HV---------------32052 Herford
jdammeyer-------------------------------------------------------------------------------------------------------7HV---------------32469 Petershagen bei Minden
Clou-----------------------------------------XSport-----3DPlus---------------------------------------6HV--------------------------32602 Vlotho an der Weser
Felix62------------------------------------------------------------------------------------------------------------7HV---------------32689 Kalletal
Uli4G3---------------------------------------------------------------------------------------------------6HV-----7HV --------------33729 Bielefeld
Mike1503-------------------------------------------------------------------------------Atom550---------------7HV----------------39615 Seehausen
Nick H.--------------------------------------------------------------------------------------------------6HV-----7HV---------------45527 Hattingen
Heli1966------------------------------------------------------------------------------------------------6HV-----7HV----------------56637 Plaidt
Pietbaer---------------------------------------------------------------Atom 500----------------------------------------------------65185 Wiesbaden
Belt V2 Crasher/ Wizard-----------------------------------------------------------------------------6HV--------------------------65812 Bad Soden am Taunus
Ensonic------------------------------------------------------------------------------------------------------------7HV--------------71144 Steinenbronn
testpilot---------------------------------------------------------------Atom 500FBL-----------------------------------------------73066 Uhingen
Sebastian Zajonz---------------------------------------3Dplus-----Atom 500-----Atom550-----6HV-----7HV------------------74626 Bretzfeld
Alex2707-------------------------------------------------------------------------------Atom550-----------------------------------82431 Kochel/82256 Fürstenfeldbruck
Sonny-1889---------------------------------------------------------------------------------------------6HV------------------------83026 Rosenheim
Bernhard Kerscher------------------------------------------Atom 500------Atom 515(473) im Bau-----------------------------84130 Dingolfing
Atom 500; Motor Stock; BeastX; Jeti; Peter Schmid FBL Kopf; MKS/Futaba; SLS2650mAh 30C
Atom 473(515) im Aufbau
Warp 360 ist bestellt
MX16s Jeti
Junsi
Zoul----------------------------------------------------------------------------------------------------------------7HV----------------32052 Herford
jdammeyer-------------------------------------------------------------------------------------------------------7HV----------------32469 Petershagen bei Minden
Felix62------------------------------------------------------------------------------------------------------------7HV----------------32689 Kalletal
Uli4G3---------------------------------------------------------------------------------------------------6HV-----7HV ---------------33729 Bielefeld
Nick H.--------------------------------------------------------------------------------------------------6HV-----7HV----------------45527 Hattingen
Pietbaer---------------------------------------------------------------Atom 500-----------------------------------------------------65185 Wiesbaden
Ensonic------------------------------------------------------------------------------------------------------------7HV----------------71144 Steinenbronn
testpilot---------------------------------------------------------------Atom 500FBL------------------------------------------------73066 Uhingen
Sebastian Zajonz---------------------------------------3Dplus-----Atom 500-----Atom550-----6HV-----7HV----------------74626 Bretzfeld
Alex2707-------------------------------------------------------------------------------Atom550-------------------------------------82431 Kochel/82256 Fürstenfeldbruck
Sonny-1889---------------------------------------------------------------------------------------------6HV--------------------------83026 Rosenheim
Bernhard Kerscher-------------------------------------------------Atom 500---Atom 515(473) im Bau----------------------84130 Dingolfing
n2o-----------------------------------------------------------------------------------------------------------------7HV----------------Kraiwiesen (Nähe von Eugendorf bei Salzburg)
Felix
evo2racer---------------------------------------------------------------------------------------------------------6HV----------------35466 Rabenau-Londorf
evo2racer-----------------------------------------------------------------------------------------------6HV-------------------------35466 Rabenau-Londorf
Felix
