Spektrum DX8 - Neue Firmware 2.05
insider
#1 Spektrum DX8 - Neue Firmware 2.05
Beitrag von insider »
Hallo an alle DX8- Benutzer!
Spektrum hat die neue Firmware 2.05 zum Download bereitgestellt. Ich liste die Neuerungen hier mal auf:
Software Features
• Added support for GPS and High Current telemetry sensors.
• Enabled up to 32-pole motors for the brushless RPM sensor.
• Enabled SD telemetry log file
• Enabled ability to configure inactivity timer
• Enabled backlight configurability (Auto/On/Off)
• Enabled dimming control of the orange Spektrum LED for night flying (gemeint ist das orange-leuchtende Symbol auf dem Sender)
• Adjusted vibe motor RPM to be less aggressive
Software Corrections
• Fixed bug that could reset the radio when scrolling through Mix options.
• Corrected L/R trimmer ‘forgetting’ assignment after power cycle.
• Improved translations in French and Italian screens.
• Corrected export of flap configuration.
• Corrected over-travel of flaps that could result in reversed operation at extreme
deployments.
• Corrected switch change on Acro throttle cut screen when going from the initial
switch selection to the edit page.
• Corrected timer to work properly in Throttle Out mode when using reversed
throttle channel.
• Corrected end-point adjustability when Trainer is used as an input to a channel.
• Corrected trainer normal Master mode so that it doesn’t modify controls from the
slave. In previous versions it could reverse channels vs. what was expected.
NOTE: This change affects sub-trim and travel of existing models and ones you
will import. You may need to adjust sub-trims and travel on all control surfaces in
both airplanes and helicopters.
Alex
Compass Atom 5.5 Beast, T-Rex 450 Beast, T-Rex 450, T-Rex 250, div. Blade-Helis, div. Multicopter, div. Flächen, DX8, DX6i
Hat sich bedankt: 8 Mal
#2 Re: Spektrum DX8 - Neue Firmware 2.05
insider hat geschrieben:• Enabled ability to configure inactivity timer
*like* :-)
insider
#3 Re: Spektrum DX8 - Neue Firmware 2.05
tracer hat geschrieben:*like* :-)
finde ich auch! obwohl man ihn wohl nicht ausschalten, sondern nur bis max. 60 min. hochsetzen kann.
Alex
#4 Re: Spektrum DX8 - Neue Firmware 2.05
insider hat geschrieben:finde ich auch! obwohl man ihn wohl nicht ausschalten, sondern nur bis max. 60 min. hochsetzen kann.
Das reicht schon.
Wie oft quatscht man sich fest, und dann dengelt da so nen Sender los, und man weiss nicht mal, ob es sein eigener ist :)
insider
#5 Re: Spektrum DX8 - Neue Firmware 2.05
Ich selber bin ja auf die Log-Funktion und die Lieferbarkeit des Hochstrom-Sensors gespannt. Die Kapazitätenmessung scheint ja noch nicht implementiert zu sein. Wäre für mich persönlich das interessanteste. Aber ich möchte nicht meckern! :D
Alex
Yaku79
#6 Spektrum DX8 - Neue Firmware 2.05
Beitrag von Yaku79 »
Mal schauen wann ich die Software einspiele.
Telemetrie kommt bei mir erst wenn Spektrum es schafft mir einen Verbrauchsgesteuerten Timer zu basteln.
Tapped via iPhone/iPad
insider
#7 Re: Spektrum DX8 - Neue Firmware 2.05
Yaku79 hat geschrieben:Telemetrie kommt bei mir erst wenn Spektrum es schafft mir einen Verbrauchsgesteuerten Timer zu basteln.
Das wäre mit dem Kapazitätensensor ja gegeben. Gelistet ist er, wie der Stromsensor auch, schon lange. Das fände ich, wie ich schon schrieb, auch das interessanteste.
Alex
IDU72
#8 Re: Spektrum DX8 - Neue Firmware 2.05
Beitrag von IDU72 »
Vermutlich ne blöde Frage und ich hoff, Ihr steinigt mich nicht: Ist das mit den fehlerhaften DX8-Anlagen eigentlich zu 100% erledigt? War das fehlerhafte Hardware oder wurden die Fehler durch ein neues Firmware behoben? Kann man die jetzt bedenkenlos kaufen (ggf. auch gebraucht und dann das neue FW-Update drauf spielen)?
Mikado Logo 600 SE (getunter Align 700 MX, Jive 80+ HV, 3x Align DS 610, 1x Savöx SH 1290MG und Microbeast)
Mikado Logo 500 3D (Savöx BSM 5055 1150KV, Jive 100+ LV, 3x Savöx SC 1257TG, 1x Futaba BLS 254 und V-Stabi 5.0-FBL)
Align T-Rex 450 Sport (Align 430XL, Koby 40 LV, 3x Hitec HS-5065MG, 1x Rockamp DS272SE und Microbeast-FBL)
alle Modelle mit der Futaba T14SG
Status: Funnel-8 und Pirouetten-Kreis funktionieren mittlerweile
insider
#9 Re: Spektrum DX8 - Neue Firmware 2.05
Hallo IDU,
da damals nur bestimmte Anlagen betroffen waren, und die auch eingeschickt werden musste, gehe ich davon aus, dass das nicht durch ein "einfaches" Firmware-Update zu beheben ist oder war. Die betroffenen Anlagen kann man auf der Spektrum-Support-Seite einsehen (im Batteriefach befindet sich ein Aufkleber). Ich bin aber der Meinung, man kann sie getrost kaufen. Notfalls schickt man sie ein. Der Service von Spektrum ist, meiner Meinung nach, erstklassig.
Alex
IDU72
#10 Re: Spektrum DX8 - Neue Firmware 2.05
Beitrag von IDU72 »
Hi Alex,
ich überlege nämlich gerade, ob ich mal auf die DX8 hochrüsten soll. Dabei hilft mir Deine Antwort sehr - DANKE!
Ingo
faxxe
#11 Re: Spektrum DX8 - Neue Firmware 2.05
Beitrag von faxxe »
insider hat geschrieben: • Corrected trainer normal Master mode so that it doesn’t modify controls from the
Nicht übersehen! Der Punkt wirkt sich auf bestehende Modelspeicherplätze aus.....
Mikado VBar Controll
MFG Weiz
elekSENDER
#12 Re: Spektrum DX8 - Neue Firmware 2.05
Beitrag von elekSENDER »
faxxe hat geschrieben:
hallo,
das kann leicht ungut werden, wenn das nicht korregiert wird.
Geht aber leicht:
Wenn ein Servokanal auf reverse steht (und nur bei diesen), dann muß Subtrimm auf den jeweiligen konträren Wert gestellt werden, also zB: 10- auf 10+ oder 37R auf 37L.
Wichtig: da gleiche gilt für auch für Travel: Wenn bei reverse-Kanälen diese Werte nicht gleich sind, müssen auch diese Werte ausgetauscht werden. zB: 90%/80% auf 80%/90%.
d.h. zuerst alle Reverse Kanäle raussuchen, dann subtrim "umkehren" bzw. wenn Travelwerte unterschiedlich sind austauschen.
lieben Gruß, Alexander
Hurricane 550 FBL: AC-3X + S9254 + 3xDES 804 BB, Tango 45-10 + Jive 80LV, Gaui FES-Kopf, Blattschmied Ultra FBL 550mm, 95mm HR-Blätter, 6s 4000mAh
CopterX 450 PRO: GAUI FBL-Kopf + CX FBL-TS, beastX + 3xDES 488 BBMG + Blue Arrow D26010, FSD/3500KV, GAUI 50A Regler + 3A BEC, Spinblades 350 halbsymetrisch, 72mm Selbstbau Heckblätter
Bell 222 mit Einziehfahrwerk: derzeit Garage, CopterX 450 Basis, GU-365 + 3xKingmax 7.5MD + FS61BB Digital, TH500 3800KV + Hobbywing Platinum 40A, Blattschmied Ultra 325
mCP X: Microheli AluKopf komplett
Flächen: Reichard Sirius, MPX FunCub, MPX Parkmaster, ACME Boomerang, Easystar "gebrushlesst"
Fernsteuerung: DX8 oder DX7 mit AR9000, AR8000, AR7000, AR6115, AR6115e, AR600, TM1000, TM1100, STi+iPod
Rastazasta
#13 Re: Spektrum DX8 - Neue Firmware 2.05
Beitrag von Rastazasta »
Gerade gesehen, dass die Spektrum™ DX8 AirWare™ Version 2.06 erschienen ist.
https://community.spektrumrc.com/Login.aspx
Kann schon jemand was dazu sagen?
Hab gerade erst gesehen, dass diese schon seit 24 Sep. verfügbar ist.
Change Log
Version 2.06
24 September 2012
Software Features
• Automatically corrects sub-trim and travel for models created in version 2.04 and
earlier after prompting the user. This is functional both for models already in
your radio, and for any you import from an SD card. You should always verify
operation of a model when making any updates prior to flying it.
• P-Link Master Trainer mode was using trainer data for channels GEAR and
higher.
• When a channel is reversed the endpoint adjustment worked on the opposite
side from what was expected.
• Improved French translations.
• Added SD logfile indicator to main screens.
NOTE: This change affects sub-trim and travel of existing models and ones you will
import. You should double-check sub-trims and travel on any reversed control surfaces
in both airplanes and helicopters when using models created in version 2.04 and earlier.
FPV: ZII, Swift Mini & Discovery Pro // Fun: Warthox Quad // @TaranisEzUhf
RC-Kleinanzeigen auf Facebook
Nymphenburg
#14 Re: Spektrum DX8 - Neue Firmware 2.05
Beitrag von Nymphenburg »
Hallo Zusammen,
aktuell habe ich die 2.0.4 auf meines DX8 und lese gerade von der Version 2.0.6
Geht ihr wirklich her und überprüft bei all Euren Modellen nach Update Travel und Subtrim?
Muss das am Modell geprüft werden oder reicht es die alten Werte zu notieren und zu übertragen?
Danke
Modelle: Ein Haufen Geraffel halt
mfs
#15 Re: Spektrum DX8 - Neue Firmware 2.05
Beitrag von mfs »
nur bei 2.0.5 musste man manuell das Vorzeichen beim Subtrimm umdrehen bzw. die TravelAdjust Werte austauschen, wenn der Kanal reversed ist.
v2.0.6 fragt beim erstmaligen Aufruf eines Modellspeichers nach dem Update ob es diese Änderungen automatisch machen soll, wenn welche notwendig waren.
- wurden diese Änderungen unter 2.0.5 bereits manuell gemacht --> NEIN antworten.
- ist es ein unverändertes altes Modell --> JA (Änderungen automatisch machen lassen)
Grundsätzlich ist es aber sicher kein Fehler, nach jeder Änderung an der Elektronik (Sender, Empfänger, Regler, ...) am Modell alles nochmal zu überprüfen, bevor man losfliegt.
lg,
Martin
Zurück zu „Sender“
