also ich habe ein 12er Ritzel drauf, das sollte er doch packen? Die Settings sind:
Code: Alles auswählen
# Castle Link Data File
# Created: Montag, 31. August 2009
# Do Not Edit This File By Hand
Hex55: 85
Brake Strength: 0
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Voltage: Auto Li-Po (*)
Current Limiting: Insensitive
Cutoff Type: Soft Cutoff
Motor Start Power: 59
Direction: Forward (*)
PWM Rate: Outrunner Mode
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 7
Initial Spool-Up Rate: 5
Head Speed Change Rate: 5
Auto Rotate Enabled: True
Governor Mode Type: High
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 3
Vehicle Setup - Battery Voltage: 11,1000
Vehicle Setup - Gear Ratio: 12,500
Vehicle Setup - Motor Kv: 3500
Vehicle Setup - Motor Number of Poles: 8
Desired Head Speed 1: 2401
Desired Head Speed 2: 2401
Desired Head Speed 3: 2401
Motor Timing: 5
Power-On Beep: Disabled
Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*)
Ciao...
Markus
