fun piccolo FP
#1 fun piccolo FP
hello... use the separate electronics . I do not succeed to shape my helicopter... 3canal (gyro)motor of tail 4canal gas..., I use mode 1, my radio is EVO9 multiplex ...
thanks
thanks
hello TRACER...I do not succeed to make the mix of the tail (3) (gyr) the channel (4) of the motor, I repeat I have one EVO9 Multiplex...I do not succeed to make this with mine radio, someone I have used this radio with Fun piccolo FP ,to even say to me like setting the radio tx
thanks
thanks
- Hat sich bedankt: 11 Mal
I don't have a EVO, so I can't tell you how to handle that on your radio
BTW, what's your native language?
@ all
Keiner hier mit ner EVO, der das mal erklären kann?
@ all
Hallo Micha,
hat er jetzt Boardless oder Piccoboard, vorallem was bekommt er nicht eiongestellt. Ich denke mal es hapert am Englisch
EDIT: OK habs gesehen , separate Electronics
OK!
Cosimo , whats your problem. What does the tail do? Sliding to the left or right? On gruond or at Hovering??? or anytime?
What are the used components : Gyro? Brand?, Motor Brushed or Brushless?
OK!
grüße Michael
hello Mataschke...the components are:
gyro colco pg03 (similar gws pgo3),
mail motor brushless himark 2700 kv pinion 9t,
for tail ,the directed motor l brushed gws 50 dd task?
3 cells 1000 Mah
now I am using in my radio the revomix, when use the stick of right, left back the motor does not turn, viceversa turns, this creed is ok... when right use the stick, where I have the gas, it does not answer too much endured or, perhaps I must settare gyro... what well thoughts of setup?
gyro motor mail ecc...better 2 cell lipoly?
3 cells 1000 Mah
Hello cosimo,
The Gyro must be Set with the Setup Screw in the Middle , so that both LED´s
Colors Green and Red lightening!
In Normal Circumstances the Tail Motor will turn at 50% when the Tail Stick is in Center position, while the Main Motor is still off. This is normal!
In this case you will be able to TakeOff without the Revo mix!
Revo mix is used to compense Pitch/Gas peaks!
The Piccolo must be in Position without Revo mix.
Try to Setup GAIN Screw , so that the Tail Stands in Position, when the Tail begins to oscillate left/right you must decrease the Gain Level.
grüße Michael
