Update 1.6 für Hyperion Duo 0610
#1 Update 1.6 für Hyperion Duo 0610
Ein neues Firmwareupdate ist raus:
Änderungen:
(1) CHARGER INTERNAL PROTECTION UPGRADE – The connection sequence of Lithium Packs with Balancer Connector (LiPo, LiFePO4) has an impact on the components inside
the charger. The connection sequence shown below reduces surges which occur at pack connection time, greatly reducing possibility of damage to charger components:
In v1.6 NET/DUO firmware, additional protection is provided such that even if correct connection sequence is NOT followed, chances of charger damage are much reduced. Even so,it is always recommended that you follow the connection/disconnection (AB-BA) sequence as shown above.
NOTE: v1.6 firmware also includes a diagnostic routine to identify chargers which have suffered internal damage. If - after updating firmware to v1.6 and attempting to balance
charge a Lithium pack - you see an error message “OUTPUT CIRCUIT ERROR” then it means that hardware components have been damaged, and you MUST return your charger for
repair/replacement before further use. NEVER continue to use the charger if you see this message after v1.6 upgrade, nor revert to earlier firmware!
(2) Buzzer under SYNC MODE Charging – fix bug in which Buzzer sounded when first pack finishes. Now buzzer sounds only when both are ready to disconnect together.
(3) Display after CC/CV END – Shows “BLC” to indicate charger is holding balance and preventing discharge until user disconnects battery
(4) When in BALANCE MODE, main pack wires need not be connected. (With or without main wires is allowed. If connecting main wires, connect them before balancer, as above)
(5) SYNC STORE MODE bug fixed, such that both packs STORE properly and buzzer ends when both are done. (ie: when the “slowest pack finishes)
http://media.hyperion.hk/dn/eos/EOS-061 ... Update.pdf
Firmware: http://media.hyperion.hk/dn/pc/ware/EOS ... -DUO16.zip
Änderungen:
Gruß Oliver
TRex 500CF FASST * Scorpion HK3026-1600 * 5S-3300 * TS 3 x S9650 * DS760+S9257 * Align 425 CFK
Trex 600 ESP FASST * Align 600M * 6S-5000-30C * BEASTX FBL
- Raptor50se
#2 Re: Update 1.6 für Hyperion Duo 0610
Danke für die Info
Ich lebe in einer 4D Welt! Das was ich fliege nennt sich aber 3D....
Trex-600N/ YS50ST mit Align D./ 3x Mpx Titan Digi4 und LTG 6100/ WC CY 30%
#3 Re: Update 1.6 für Hyperion Duo 0610
Da geht ja recht schnell was weiter
Mich schokiert nur die Tatsache, das ich den Lader schrotten kann, wenn ich erst den Balancer, dann den Strom anstecke.... Zumal bis jetzt davon keine Rede war
cu
Andi - der heute auf 1,6 upgraden wird, und hofft das sein Lader keinen weg hat
cu
Walkera 4#3B
MX16s
The memory remains
20.08.1983 - 18.08.2008
Walkera 4#3B
MX16s
The memory remains
#4 Re: Update 1.6 für Hyperion Duo 0610
Mich auch, zumal ich es bisher immer so gemacht habe. Zuerst den Balancer und dann + & -ToxicTear hat geschrieben: Mich schockiert nur die Tatsache, das ich den Lader schrotten kann, wenn ich erst den Balancer, dann den Strom anstecke.... Zumal bis jetzt davon keine Rede war
-heimo
TT Raptor e720 // Quantum 4530 // Kosmik 160+ // 3xJR-8925HV // BLS256HV // Vstabi 6.0
GAUI Hurricane 550 im Hughes500e Rumpf ---> Bilder // Flugvideo --> MD500E@YouTube
Mikado VBar Controll
MFG Weiz
____________________________________________________________________________
MFG Weiz
#5 Re: Update 1.6 für Hyperion Duo 0610
Beim einstecken der Anschlüsse hat es bei meinem Duo immer gefunkt,
deshalb habe ich den Balancer immer zuletzt angesteckt. Die 4mm Goldis
vertragen solche Blitze sicherlich besser als die kleinen Balancerkontakte.
Seit ich das 1.6 Update drauf habe, ist das Funken verschwunden.
Gruß H.
#6 Re: Update 1.6 für Hyperion Duo 0610
rate mal wer das noch so gemacht hat....faxxe hat geschrieben:Mich auch, zumal ich es bisher immer so gemacht habe. Zuerst den Balancer und dann + & -
bin das so gewohnt von meinem Ultramat 14 + LiPo Balancer Plus. Da muss man erst den Balancer anstecken....
Kann ich auch bestätigen. Hab gestern das Update aufgespielt und mit Erleichterun festgestellt das mein Lader noch immer funkt Das Funken aber ist verschwundenFlyfrog hat geschrieben:Seit ich das 1.6 Update drauf habe, ist das Funken verschwunden.
cu
Andi - der den Lader immer noch super findet
Walkera 4#3B
MX16s
The memory remains
Walkera 4#3B
MX16s
The memory remains
#7 Re: Update 1.6 für Hyperion Duo 0610
Hallo !
Für die Leute, die mit dem Englischen Probleme haben, habe ich ein Infoblatt bezüglich der Hyperion Firmware V1.6 auf den Server gelegt:
http://www.stein-elektronik.de/EOS-0610iXv16-ManDE.pdf
Hans-Willi
Hans-Willi
#8 Re: Update 1.6 für Hyperion Duo 0610
Stein hat geschrieben:Hallo !
Hans-Willi
Das nenne ich ja mal Service!!!
#9 Re: Update 1.6 für Hyperion Duo 0610
Fein, jetzt muß nur noch mein USB-Kabel herbeikommen und dann kannßs fast losgehn. Das Firmwareupdate bekommt man ja direkt im Hyperion-Supportbereich, oder wie war das ?
Gibts eigentlich mittlerweile ein Programm zum loggen eines Akkus beim laden, das mit dem 0610i Duo arbeitet ? Wäre für mich noch sehr interessant.
#10 Re: Update 1.6 für Hyperion Duo 0610
Hi !
Ja gibt es...
Software
http://media.hyperion.hk/dn/pc/ware/EOS ... Beta09.exe
Firmwareupdate V1.6 für das Duo
http://media.hyperion.hk/dn/pc/ware/EOS ... -NET16.zip
Hans-Willi
Ja gibt es...
Software
Hans-Willi
#11 Re: Update 1.6 für Hyperion Duo 0610
Super, H.W. - besten Dank !
#12 Re: Update 1.6 für Hyperion Duo 0610
Sorry für die doofe Frage, aber wie funktioniert so ein Firmwareupdate? Benötige ich dazu ein zusätzlichen Kabel?
Gruß Tim
#13 Re: Update 1.6 für Hyperion Duo 0610
Yep, ein USB-Kabel das den Lader mit dem PC verbindet. Gibbet auch von Hyperion.
#14 Re: Update 1.6 für Hyperion Duo 0610
jap - logwiev schafft dasCrizz hat geschrieben:Gibts eigentlich mittlerweile ein Programm zum loggen eines Akkus beim laden, das mit dem 0610i Duo arbeitet ? Wäre für mich noch sehr interessant.
In der DL Version sin die Treiber für das DOU GLAUBE ICH noch nicht eingebunden. Ich habe aber auf Anfrage eine Beta version erhalten. Funkt
cu
Andi
Walkera 4#3B
MX16s
The memory remains
Walkera 4#3B
MX16s
The memory remains
#15 Re: Update 1.6 für Hyperion Duo 0610
Dito! Ebenfalls vom Lipo Balancer Plus (mit Simprop Intelli BiPower) so gewöhnt! (Mache das auch beim Intelli Bi-Power Special so...).Mich auch, zumal ich es bisher immer so gemacht habe. Zuerst den Balancer und dann + & -
Jetzt weiss ich wenigstens warum vor ca. 1 Monat aus meinem Duo weisser Rauch aufgestiegen ist
(vorher hat es auf einer Seite immer Outbut Battery Open Circuit angezeigt und nicht geladen, hatte deswegen schon beim Händler angerufen, und dann das...)
Wurde aber anstandslos sofort im Laden ausgetauscht (bei Freakware).
Viele Grüsse
Logo 500 3D V-Stabi -> Bell LongRanger
V-Stabi | Emcotec | TS: DS8822 | BLS251 | Jazz 80-6-18 | Orbit 25-08HE | Kokam H5 6S1P 4000 | Helitec 550CFK | V-Tails 95 | Alle Mikado-Tuning-Teile
Eco7 Sport Brushless + Boardless
GY401 | HS81MG | Jazz 80-6-18 | Hacker C50-L-14 | Robbe RO-Power 3S1P 5000 / Kokam H5 3S1P 4000 | Helitec 470CFK | Alu-Rotorkopf | Freilauf | Alle Wellen gehärtet
Blade MSR, Twister Skylift mit Schlepphaken und weiteres Kleinzeugs (Auch mit nicht drehbaren Flügeln)
Funke: MX-24s Spektrum 2,4
