Easy Star
Razor04
#1 Easy Star
Beitrag von Razor04 »
Hello all,
sorry for writing in English,bin Englander :D
My question is i want to buy a Easy Star plane,i have already a esky 6 channel Reciever (EK2.0420A) what i took out of my Honeybee King 2 Helicopter.
Can i use this Reciever with my 6 channel Transmitter also with plane?(esky 0406A)
Mfg David Wilkinson
Gerry_
Been thanked: 1 time
#2 Re: Easy Star
Beitrag von Gerry_ »
Hello David.
You don't have any mixers inside your transmitter, so you can use it for flying Easy Star without problems.
Just take care that the channel reverse settings are correct.
Easy Star is very easy to fly. A well working rework is an increase of the rudder. So you will have less problems to fly while its a little windy.
Best regards ;)
Gerry
Has thanked: 5 times
Been thanked: 4 times
#3 Re: Easy Star
Welcome David.
Is this your transmitter?
http://www.buzzflyer.co.uk/ESky-0406A-T ... -Guide.asp
It's not a computer transmitter, so it's not capable of being programmed for special use cases.
It's designed to fly a eCCPM helicopter like the belt cp, I see no chance in changig the setup.
The problem is that there are build in mixers for the 120° swash plate.
#4 Re: Easy Star
Gerry1973 hat geschrieben:You don't have any mixers inside your transmitter, so you can use it for flying Easy Star without problems.
Does the belt / Honey Bee have an internal mixer in the control unit?
OK, then I was wrong.
Maybe just try it by putting a servo on each needed channel, and check out, what the servo does when moving the appropiate stick.
Memphiz
#5 Re: Easy Star
Beitrag von Memphiz »
The Mixers in the ESky Transmitter can be disabled by playing with the 2 dipswitches which are located below the batterys. It shouldn't be a problem using this RC-Set for flying an EasyStar.
ciao
Christian
Prôtos 500 FBL (3xDS510, Roxxy 960-6, AR6200, Orig.Motor 15T, BeastX, 9257, SAB Blades)
Align T-Rex 450 SEV2 - Silver (3xHS65HB, Roxxy 940-6, AR6100e, Scorpion HK2221 8 13T, LTG 2100, HS5084MG, Radix Blades)
Funjet
Fox RC
Kyosho Outrage (Ansmann Clash 15, Hitec Regler)
Blade mCX
Spektrum DX6i
Zurück zu „EasyStar“
