für die Aurora 9-Flieger unter euch: Von HiTec ist nun die Software-Version 1.07 für die Aurora 9 und die Version 2.00 für die Empfänger und das Spectra-Modul erschienen. Man benötig aber eine neue Version der HPP-22-Software (V1.02), die es bei HiTec USA zu beziehen gibt (die deutsche HiTec-Seite hat es noch nicht).
Hier mal die Features der neuen Software:
Version Information.
HPP-22 v1.02
- Aurora 9 v1.07 Upgrade Information.
Added Functions:
- System Password Lock Function: You can't have system access without correct password.
- Quick Model Select Function: You can confirm & select your model from the start up screen.
- Receiver Battery Low Voltage Warning Function: You can select the Low Battery Warning Alarm activation level.
- Touch Beep Sound On/Off Function: You can turn on and off touch screen button sound.
- Touch Screen Calibration Function: Now you can do touch screen calibration for your Aurora 9.
- Warning Selection at Start up Function: Now you can choose to turn on or off for two conditions of startup warnings
(Abnormal Throttle and Flight Condition)
Modified Functions (improved):
- Timer Reset Method: Press & hold the Timer (1 or 2) screen for about 2 seconds which you want to reset.
Etc.:
- Menu Name Changed: Power > SYS. MGMT, Auto Power Off > Auto Hibernation.
- SPECTRA 2.4 v2.00 Upgrade Information.
Low Battery Warning Function
HTS-SS 2D display
- OPTIMA 7/9 v2.00 Upgrade Information.
