Verkaufspreis € 55,-. Neupreis war bei ca. € 70,-.
NEU und noch nie benutzt. Versandt möglich für zzgl. € 4,-.
English :
• Special greaseproof/waterproof design, much reduce damages caused by fuel and water infiltration.
• Add filter capacitor for high frequency interference, to efficiently reduce the outside interferences(ex. High speed/torque servos).
• Due to the unique 2 in 1 design, the regulator¡¦s functions provide power to the receiver, servos, and the internal glow plug ignition system that does not require you to remove the clip lead.
• The linear regulator design results in no interference to the receiver. The required input power may only consist of a 2 cell Li-ion or a Li-Poly battery.
• When the integrated power switch is moved to the on position, the voltage indicating LED¡¦s and ignition indicating LED¡¦s will illuminate displaying the status of the battery voltage, and of the plug ignition function.
• Input voltage: DC 7.4V 2CELL Lithium battery
• Output voltage:6A 5.8V(For reciver/servo)
5A 1.5V(For Glow plug)
• Max. continuous current: 6A
• Regulator size: 80x30x13.3mm
• Control board size: 35x24x10mm
• Weight: 53.5g(including wire set)
2S1P 7.4V 1900mAh/18C Ratings:
• Output:7.4V(2S1P)1900mAh
• Rating:18C continuous,25C burst
• Dimension:89x35x17.5mm
• Weight:102g
