Align 35A Brushless ESC RCE-BL35XHallo
Verkaufe einen neuen Align 35A Brushless ESC RCE-BL35X
Der Regler stammt aus meinem T-Rex Sport Combo, An den Regler wurde nur ein Grüner MPX Stecker gelötet.
Mit Programmieranleitung
Daten des Herstellers:
BEC output voltage(6V) to show great performance on the torque & speed of servo.
Three programmable throttle speed settings to support quick throttle response.
Govener Mode(governor speed controller?slow down system).
Small and compact PCB design for ease of installation.
Large heatsink for great thermal performance.
High compatibility to work with 98% brushless motors in the market.
Ultra smooth motor start design to run with all kinds of brushless motors.
The power inlet adapts Japanese made "Low ESR" capacitor in order to provide stable power source.
T BEC power outlet adapts a Japanese made specialty polymer aluminum electrolytic capacitor. It porvides better noise filtering capability than other BL ESC in the market, and moreover to give more stable performance of R/C receiver and BEC.
The BEC adapts dual TO-252 package regulators. It provides great thermal performance with 2A peak current.
The throttle has more than 200 steps resolution that provides great controlling sense.
Users can use the transmitter to operate the motor setting by Super stylized CPU.
Contimuous current:35Amps with porper air flow
Surge current:45Amps for 15seconds
Supporting motor types:2 poles to 10+poles in/outrunner brushless motors
Supporting maximum RPM:2poles=>190,000rpm
Supporting input voltage:5.5V~16.8V
Supporting battery types: Li-ion/ Li-poly 2~4 cells, Ni-Mh 6-12 cells
BEC output: Max current 2A
2 cells Lithium/6~7 cells Ni-Mh=>4servos
3 cells Lithium/8~9 cells Ni-Mh=>3servos
4 cells Lithium/10~12 cells Ni-Mh=>2servos
Weight:25g
Preis: 35 Euro incl. Versand in D. ( Luftpolsterbrief )
Preisupdate jetzt für 30 Euro incl. Versand
Align 35A Brushless ESC RCE-BL35X (Preisupdate )
#1 Align 35A Brushless ESC RCE-BL35X (Preisupdate )
Verkaufe:
1x Easy Glider Pro ( neu ) Flugfertig ohne Empfänger 150 Euro
1x Parkmaster Flugfertig ohne Empfänger 80 Euro
Beide nur Selbsabholung in Bayern
Bei intresse PN an mich, dann gibts alle Auskünfte und Bilder
