Hallo Verkaufe
3 Stück Hyperion DS20x SMD Servos
VB 80,-
Technische Daten
HP-DS20x-SMD
Servo type Fully programmable full size digital coreless servo
Dimensions mm 40.0 x 19.5 x 36.5
Weight gram 52.5
Speed (sec/60 deg @ 4.8/6.0V) 0.13/0.11
Dynamic torque (kg/cm @ 4.8/6.0V) 7.0/8.0
Holding torque (kg/cm @ 4.8/6.0V) 14.0/16.0
Gear Train primary material Metal
Bearing Double ball
Programmable Yes, with free PC software connected via USB adapter (HP-HP-AT-PRGUSB)
Rotation in degrees Adjustable 30 to 140 degrees total, 90 degree default (45 each way)
Adjustable travel speed Yes, 1% to 100% of Rated Speed (100% default)
Maximum input voltage Unloaded input voltage should never exceed 7.8V, loaded input voltage max 6.6V
#1 Hyperion DS20x SMD Servos
___________________________________________________________
Suzi-Hans, Henseleit MP-XL-E, Furion 6, Schlüter HeliBaby Baujahr 1975
