MSHeli Help
HighFreq
#1 MSHeli Help
Beitrag von HighFreq »
Hello everybody, this is Corrado if anybody needs help on the Protos or Mini i'll do my best to answer here.
Please write on this thread and not in privat so answer to question can be useful to other users too.
Please write in English, my german is not so good :oops:
Corrado :mrgreen:
echo.zulu
#2 Re: MSHeli Help
Beitrag von echo.zulu »
Hi Corrado.
Welcome to our community. Thank you for joining us. :wav:
torro
#3 Re: MSHeli Help
Beitrag von torro »
Hi Corrado! :P
Gruß, Flo
mozart1982
#4 Re: MSHeli Help
Beitrag von mozart1982 »
hello Corrado ! :)...
Outrunner
#5 Re: MSHeli Help
Beitrag von Outrunner »
Hi Corrado
Wow, that's what I call premium customer support 8)
torro
#6 Re: MSHeli Help
Beitrag von torro »
Question No1:
i´ve little problems with the one-way or rather the bearings.
the one-way fits perfectly on the adaptor, but not the bearings.
i don´t want to mount the bearings with force, so i had to sand the complete adaptor.
I tried a few bearings, all had the same problem.
since we use motors like this... :P
55x1.12yy 10.jpg (110.02 KiB) 1567 mal betrachtet
... i´m afraid, that the one-way gets problems with the smaller diameter of the adaptor.
these motors eliminate bad one-way´s without mercy :roll: :twisted:
Gruß, Flo
macem
#7 Re: MSHeli Help
Beitrag von macem »
hi corrado ... nice to have contact directly... :!:
.. i would like to use my older scorpion 2221-12 on the mini-protos - so i have to cut the motorshaft? correct? any special things to look at, when doing that?
macem
HighFreq
#8 Re: MSHeli Help
@ Torro, i am not sure i understand your problem.
@Macem, yes you have to cut your motor shaft. When doing it, make sure not to overheat the shaft and pack the motor with a plastic bag so no debris get inside.
Corrado
torro
#9 Re: MSHeli Help
Beitrag von torro »
HighFreq hat geschrieben:@ Torro, i am not sure i understand your problem.
you have the pinion and two bearings for it.
the pinion fits perfectly on the adaptor, the bearings not.
i had to sand the adaptor, to fit the bearings.
Gruß, Flo
b3nJi
#10 Re: MSHeli Help
Beitrag von b3nJi »
Hello Corrado !
Nice to meet you HERE :mrgreen:
Mini Prôtos Stretch: SAB350mm, 3xSH-0254, 1x S9257, MICROBEAST, SMC16Scan, Scorpion HK2221-16 2010Kv, MSH/YGE60, 16T Pinion, 4S1800
Prôtos 500 CFK Stretch: SAB470mm, 3xSH-1350, 1xDS620, ACT Slim-8 S3D, MICROBEAST, YGE120, HK3026-12N14P (5+4x1,18D 840kV) 14T Pinion, 6S2650
Raptor 50 Titan: GCT600mm, SMC16Scan, 2x 3152, 1 HS-645MG, 1x DS620 + GY401, Throttle Jockey PRO + S9254 + OS MAX 50 SX-H Hyper + Krumscheid Reso, 30%N
T-Rex 700E V2-Stretch: NitroHeckgetriebe (1:4,95), Align 105mm, Align 800mm, 3xDS610, 1xDS650, MICROBEAST, Align RCE-B6X BEC(6A), Align BL700MX (470Kv), Castle ICE2HV 120A, 12S5000
Funke: MX16s mit ACT S3D Uno-Umbau
torro
#11 Re: MSHeli Help
Beitrag von torro »
Please sell the third BB support separately!!!
Gruß, Flo
macem
#12 Re: MSHeli Help
Beitrag von macem »
HighFreq hat geschrieben: ...
Corrado
ok, thanks a lot ... how long should the shortened, outstanding part of the motorshaft be, to fit into the adaptor? is there any tolerance?
regards, macem
torro
#13 Re: MSHeli Help
Beitrag von torro »
go on msheli.com, there is a manual.
Gruß, Flo
macem
#14 Re: MSHeli Help
Beitrag von macem »
... thanks to flo,
... but i checked the manual already and did not find any reference to the motorshaft...,
regards, macem
torro
#15 Re: MSHeli Help
Beitrag von torro »
hab übersehen, daß Du den Mini meinst :oops:
Gruß, Flo
Zurück zu „Protos 500“
