FR-Sky Taranis Erfahrungs und Laberthread
satsepp
#91 Re: FR-Sky Taranis Erfahrungs und Laberthread
Beitrag von satsepp »
Mischerberechnung haben sich geändert, ansonsten muss ab zúnd an ein Haken gsetzt werden wie bei Lautstärke etc. ist nichts tragisches.
Du musst sowieso alle Modelle 100% prüfen nach dem Update, auch Ansagen und Telemetrieschirme.
Sepp
Meine Flotte:
satsepp
#92 Re: FR-Sky Taranis Erfahrungs und Laberthread
Übrigens für Leute die noch nicht umgestiegen sind hier mal eine Änderungslog was geändert wurde:
Version 2.0.4 / 2014-06-24
[Taranis]
Lua Telemetry custom screens added
Lua wrong memory used indication
Telemetry on the serial port in the battery bay
[All]
Air Speed added in Logs
|d|>x bug fix
Timers played even if 00:00
Version 2.0.3 / 2014-06-17
Bugfix on Reset Flight function (possible freeze of the menus)
Imperial units bug (on altitude)
FIRMWARE.BIN and EEPROM.BIN are not anymore marked as system files
Version 2.0.2 / 2014-06-12
RxBatt removed (merged with A1 as before)
Bootloader accessible through the 2 trims (as 2.0.0)
Delay on switches middle position only applied to Play functions
Delay for Play functions is configurable (0-300ms)
SWR, A3 and A4 now recorded in SD logs
Persistent mAh was not correctly stored in EEPROM
A lot of small bug fixes
OpenTX 2.0.1 / 2014-02-05
[Taranis]
S.PORT / D protocol choice added in TELEMETRY menu
Heli mixer fix (stick modes 2/3/4)
Multipos switch fix
Italian translations updated
French translations fixes
Multis Wizard added
Bootloader now needs only one trim pressed
S3 warning hidden (no S3 on Taranis)
Persistent mAh was broken
[Stock]
Fix for LS used as source
[All]
Fix on d>=x logical switches
OpenTX 2.0.0 / 2014-06-02
[Taranis]
Inputs layer with support for all physical inputs and telemetry
Lua interpreter for runtime scripts and one-time configuration assistants
GVARs useable for offsets and limits
GVAR modification popup on home screen can be enabled/disabled for each GVAR
Output curve assignable to each servo on the SERVOS page
32 curves instead of 16, with smoothing, and any number of points between 2 and 17
Pot position memory for the 4 pots, with startup warning
Copy/paste/insert/delete of custom function lines
Altitude can be displayed in the top bar
FrSky Taranis will run at 120MHz instead of 60MHz
New trim system (a mode's trims can be relative to that of another mode's)
SPORT data form internal module available on the UART connector in the battery compartment in the Taranis
Support for 6-position pots, with individual positions available in the switch selection list
Taranis will be useable as a standard PC joystick through USB, 8 analogs and 8 buttons mapped to CH1-8 and 9-16 respectively
[ARM Boards]
Measured consumption (mAh) can be stored on power off
0.1% resolution for limits
Sound repeat time settable in multiples of 1sec, call at model load can be disabled
3 options for timer countdown voice output
9 GVARS instead of 5 (ARM boards only)
64 custom functions instead of 32
Ability to read text files from the SD card. A file with the name of a model will be linked to it and easily accessible as "model notes". Can be displayed automatically at model load for use as a checklist
Bootloader added, removes the need to install computer drivers to flash new firmware
Radio can handle EEPROM conversion by itself (no need for companion)
Improved vario sounds
Default audio files can be placed on the SD card for each model for all switch positions (both for physical and logical switches).
Support for up to 16 channels on trainer input
[All]
Proportional fonts
Switch warnings can be disabled for switches you don't use on a given model
Compensation for offset error of FrSky FAS-xx current sensors (option on m64)
Companion merged into OpenTX
Companion major code / graphics refactoring
Sticky Logical Switches
ASpd, dTE, Cel-, Vfas- added to Telemetry values
Workaround for newer bogus FlySky modules that send out servo centers on powerup (9x only)
Finnish language support
2940 / 2014-02-02
[ARM Boards]
Wav files played even in silent mode
GPS support had broken VFAS
[All]
Custom function triggered by a CSW based on analog triggering erroneously at powerup
Problem with mixer weight field when !GVARS
PPM5 was broken
Muss nun alle Modelle wieder auf A1 ändern und die Alarme neu einstellen, umgestellt habe ich schon.
Das was wie Jungs leisten ist echt der Hammer, ich kenne keinen anderen Hersteller der da mit Transparenz und Qualität bezüglich Software mithalten kann.
Sepp
Sepp 2014.06.24.zip
(15.12 KiB) 117-mal heruntergeladen
Meine Flotte:
dive26
#93 Re: FR-Sky Taranis Erfahrungs und Laberthread
Beitrag von dive26 »
Vielen Dank, lieber Sepp, für diese wirklich lange Neuheitenliste!
Sobald mein Ersatzsender da ist, werde ich dort die neue Software ausprobieren. Am Hauptsender mag ich zur Zeit nicht Updaten, da jetzt alles so gut läuft :wink:
Der Wahnsinn: Die Taranis bekommt man derzeit weder in China noch in Europa. In den USA konnte ich gerade noch ein Exemplar ergattern.
Letztens am Flugfeld meinte ein Vereinskollege ich solle doch am Segler Klappen programmieren (fliege erst seit 2 Wochen Fläche). Ich mischte vor Ihm die Klappen dazu und er meinte nur "WOW - so viele Funktionen - und was man da alles damit machen kann ..." :mrgreen: :wink:
Unser Vereinsobmann meinte auch vor ein paar Tagen "Dieser Sender scheint doch mehr zu taugen als ich anfangs angenommen hatte.". :mrgreen:
Und ein anderer Vereinskollege meinte "Ich wollte mir das Teil auch zulegen, aber scheint schon wieder überall ausverkauft zu sein - wäre toll wegen Lehrer Schüler Flüge ..."
Zu diesem Thema hätte ich zwei Fragen:
a) welches Kabel brauche ich für Lehrer/Schüler? Wie ist es verschalten?
b) kann man bei der Taranis auch per Funk Lehrer/Schüler machen?
LG Roland
satsepp
#94 Re: FR-Sky Taranis Erfahrungs und Laberthread
LS geht ganz einfach, dazu geht ein ganz normales Audiokabel die ich nutze. damit dann auf Spektrum Beispielsweise *g*
kann Dir dazu eventuell Heute abnend ein bisschen was schreiben, bin in der Arbeit.
Im Hauptmenu Punkt3 ist die Schüler Kalibrierung und zuordnung zu machen, in einer CF dann aktivieren.
Das aktivieren kann auch über den Schülersender erfolgen (jeder Schüler-Kanal kann als Quelle für Mischer und CF etc. dienen!) was bei FPV der Hit ist. Das heißt Beispielsweise ein Spektrum sender legt einen Schalter um und steuert dann die Taranis fern!
Da werden die Augen der eingefleischten Teuersenderanlagen ganz groß und die Kinnladen klappen weit nach unen. :shock:
Sepp
Meine Flotte:
dive26
#95 Re: FR-Sky Taranis Erfahrungs und Laberthread
Oha, also kann auch eine schnöde Spektrum Fernbedienung als Lehrersender fungieren ?!
Burnsi
#96 Re: AW: FR-Sky Taranis Erfahrungs und Laberthread
Beitrag von Burnsi »
Ich weiß auch gerne als Lehrer für ne 9x fungieren.
Aber ich habe keine Ahnung wie man das macht.
Gesendet von meinem Toaster im Bräunungsgrad 3
Burnsi
T-Rex 600 ESP
T-Rex 500 ESP
Gaui 425
Blade 130X
satsepp
#97 Re: FR-Sky Taranis Erfahrungs und Laberthread
dive26 hat geschrieben:Oha, also kann auch eine schnöde Spektrum Fernbedienung als Lehrersender fungieren ?!
Ja dadurch kann auch jeder Spektumsender ein RC-Modell in 3,5km Entfernung Sicher steuern weil die Taranis den HF-Teil erledigt. Weiter bin ich bisher nicht geflogen, bin aber nur wegen zu neige gehender Lipos umgedreht!
Und das mit dem X8R, der L9R würde Grundsätzlich doppelt so weit gehen, aber eben ohne Telemtrie.
Sepp
Meine Flotte:
satsepp
#98 Re: FR-Sky Taranis Erfahrungs und Laberthread
So nun mal das ganze was gemacht werdne muss am Beispiel vom Modell 25 (siehe Seite vorher meine Modelle).
Hier habe ich auf eine DX7 Kalibriert wo zusätzlich 1 Kanal falsch lief. Bevor der Kollege sein aktives Modell umstellen musste habe ich das schnell ungedreht:
wenn die Verbindung besteht (die Werte ändern sich) alle Knüppel am Schülersender auf Mitte und dann links unten Kalibrieren drücken!
Mit dem Faktor in etwa anpassen dass 100% gesteuert werden können.
Dann entweder einen Schalter auf einer CF beutzen um den Lehrermode zu aktivieren, oder eine CS der dann auch mit einem Port vom Schülersender versorgt werden kann so wie im Modell 25:
Und dann den L7 auf die CF legen:
Anstatt alles freizugeben kann auch geziehlt jede der 4 Funktionen (Gas/Seite/Quer/Höhe) seperat aktiviert werden.
Das ist alles!
Sepp
Meine Flotte:
dive26
#99 Re: FR-Sky Taranis Erfahrungs und Laberthread
Im Facebook wurde gerade geschrieben, dass aus der USA gekaufte Taranis Sender eine höhere Sendeleistung hätten?
Ist das wahr? Ich habe mir eine aus den USA bestellt, weil sonst nirgends eine lieferbar war.
Mittlerweile habe ich auch eine zweite die schon auf dem Weg zu mir ist. Nun habe ich 3 (eine zuviel) :mrgreen:
satsepp
#100 Re: FR-Sky Taranis Erfahrungs und Laberthread
Du kannst jede auf USA umstellen aber darfst Sie dann nicht betrieben bei uns. Ist in den globalen Einstellungen der Ländercode!
Sepp
haptik 2.jpg (139.92 KiB) 2381 mal betrachtet
Meine Flotte:
dive26
#101 Re: FR-Sky Taranis Erfahrungs und Laberthread
Hallo Sepp,
wie muss das Kabel für Schüler/Lehrer verkabelt sein? Stereo oder Mono Klinke? 1:1 duchgeschalten oder gekreuzt?
LG Roland
satsepp
#102 Re: FR-Sky Taranis Erfahrungs und Laberthread
ich habe stero, denke 1:1 sind die normalen Audiokabel
Sepp
Meine Flotte:
dive26
#103 Re: FR-Sky Taranis Erfahrungs und Laberthread
Habe heute meine zweite Taranis erhalten (diesmal nicht von HK sondern von Engel Modellbau).
Unterschiede:
Lautsprecher und Säuseln:
HK: kein Säuseln
Engel: Säuseln, wenn Sendemodul aktiv ist (im Lehrer Schüler-Betrieb ist es weg).
Seitliche Potis:
HK: gehen ruckelig, sehen billig aus und Mittelstellung ist fast nicht zu spüren
Engel: gehen smooth, sehen wertig aus und es gibt eine deutlich spürbare Mittelstellung
Obere Drehpotis:
HK: keine Mittelstellung spürbar
Engel: Mittelstellung deutlich spürbar
Wie habt Ihr das Säuseln in den Griff bekommen?
Bin nun dabei auf die zweite die neue Firmware draufzuspielen und meine Modelle zu überspielen. Nur so zum Test ob auch alles klappt.
Wenns nur A1 auf RXBAT ist, dann solls ja nicht schwierig sein. Wenn alles klappt, dann kommt auch auf die erste Taranis die neue Firmware drauf.
Und anschließend wird mal Lehrer/Schüler ausprobiert (nehm aber erstmal meinen Styroporsegler zum üben) :mrgreen:
LG Roland
dive26
#104 Re: FR-Sky Taranis Erfahrungs und Laberthread
Ich habe mich gerade etwas gespielt, bin aber noch nicht weiter gekommen.
Was mich wundert: von Schüler auf Lehrer kann man nur 4 Kanäle übertragen?
So wie bei Deinem Screenshot siehts auch bei meinem Lehrer Sender aus.
Bei einem Heli ist Gas (Thr) nicht so wichtig, aber Pitch sollte übertragen werden.
Pitch liegt bei meinem Sender auf Kanal 7. Wie kann ich neben Nick, Roll und Heck auch Pitch (statt Gas) übertragen?
Sollte man das Ergebnis der Lehrer-Schüler Übertagung auf dem Lehrer-Servomonitor sehen können?
LG Roland
dive26
#105 Re: FR-Sky Taranis Erfahrungs und Laberthread
Wieder was in der neuen Firmware entdeckt.
Ich hatte doch auf dem Schalter SH bei kurzem Ziehen (SH|s) die Empfängerspannung (A1) und bei längerem Ziehen (SH|l) die Akkuspannung (TX-Akku).
Nach dem Update gibt es aber scheinbar keine s wie short und l wie Long beim Schalter SH.
Nach langem Googeln und probieren konnte ich es mit Logischen Schaltern und der Puls Funktion (Custom Switch and EDGE) hinbekommen:
Zurück zu „Sender“
